TwinTurbo.NET: Nissan 300ZX forum - I use the same method of 'drawing' the trans into the
Subject I use the same method of 'drawing' the trans into the
Posted by Gordo 93TT Daytona on August 31, 2008 at 11:41 PM
  This message has been viewed 120 times.
In Reply To If you used the alignment tool posted by RedTTZ91(OK) on August 30, 2008 at 10:00 AM
Message engines pilot bearing. Instead of a bolt, when the trans is within a 1/2" of being flush; I used a couple of slip-joint pliers to pull the two flanges together. The idea is the same as using a bolt. Also like everyone says, you have to wiggle and turn things to get just the right fit. gordo
_________________________________________________
