TwinTurbo.NET: Nissan 300ZX forum - Was the clutch alignment tool easy to pull in and out
Subject Was the clutch alignment tool easy to pull in and out
Posted by TTFairladyZ on August 31, 2008 at 10:44 AM
  This message has been viewed 110 times.
In Reply To im trying to use the 5spd from my 96 and the jdm motor .... posted by PandaManZ32 on August 30, 2008 at 01:55 PM
Message after the pressure plate was bolted down?
One thing that you could/could've done is bought 2 bolts
that are similar thread and length to the stock tranny bolts
around 9 and 3 o'clock on the bell housing. Cut off the hex
head of the bolt and dremel a slot where that used to be to
allow a flat head screwdriver to be used. This could be used
as guides to get the trans perfectly lined up everytime.
This was posted by some member here previously, never tried
by me however.
Since it's always a one man job with removal and install of
my trans, I use two 2 ton jacks (one on the bell housing,
and the other just behind the oil drain plug on the trans)
to orchestrate leveling out the trans as best as I can by
raising and lowering each jack, while pushing from the rear
to close the gap.
1990 Nissan 300ZXTT Stage III+
Pure sports car, 100% daily driven (dry/rain/snow)
