TwinTurbo.NET: Nissan 300ZX forum - Re: Well it looks like my knock sensor is shot so that will be
KasbeKZ
on August 29, 2008 at 9:53 PM
posted by jmt-z
on August 29, 2008 at 04:10 PM
i doubt it. mine was bad and doing the bypass trick made no difference in the way the car ran
Loss of power....
jmt-z
09:20:12 08/29/08
Re: Loss of power....
KasbeKZ
09:39:27 08/29/08
Re: Re: Loss of power....
jmt-z
10:08:43 08/29/08
Regapped the plug...checked all my vacuum hoses and went for
jmt-z
10:32:20 08/29/08
KasbeKZ
10:45:51 08/29/08
It sounds just fine. When I step on the gas its almost
jmt-z
11:19:30 08/29/08
perhaps you have clogged catalytic converters ??? (n/m)
REDI4U
14:06:42 08/29/08
Re: perhaps you have clogged catalytic converters ???
KasbeKZ
14:36:37 08/29/08
Ill add that to my list to check when i get under there
jmt-z
14:43:46 08/29/08
KasbeKZ
14:37:56 08/29/08
Ill take a look at these too but I was under the impression
jmt-z
14:49:28 08/29/08
my guess is the clogged cats...especially if it idels fine (n/m)
REDI4U
14:57:35 08/29/08
Re: Ill take a look at these too but I was under the impression
KasbeKZ
16:21:42 08/29/08
jmt-z
16:10:15 08/29/08
Re: Well it looks like my knock sensor is shot so that will be -
KasbeKZ
21:53:33 08/29/08
Well I soldered on a 1M ohm resistor and problem solved
jmt-z
14:46:17 08/30/08
Re: Well I soldered on a 1M ohm resistor and problem solved
KasbeKZ
20:13:06 08/30/08
