TwinTurbo.NET: Nissan 300ZX forum - Remanufactured Injectors?
Subject Remanufactured Injectors?
Posted by WC on August 28, 2008 at 9:57 PM
  This message has been viewed 463 times.
In Reply To Remanufactured Injectors? posted by WC on August 28, 2008 at 05:00 PM
Message After spending 20 hours changing the first injector, it still ran on less than all 6 cylinders. I tested the injectors again and found one with a very hight resistance. As the engine heated, it started to idle better. I checked the resistance again and it had dropped to about 20 Ohms. The car ran great for about a week, then the same injector started to fail randomly, then died completely (open circuit). I changed the second bad injector (took only 10 hours), and the car ran perfect. After it had been parked for about a week, it started on 5 cylinders. It was running perfect when I shut it off the week before.
All corrosion has been cleaned off of the injectors and I replaced all of the harness plugs.
I am very tempted to try the remanufactured injectors. I am concerned about mixing 4 reman injectors with 2 new ones.
I would like to hear from anyone who has had a good, or bad experience with remanufactured injectors.
