TwinTurbo.NET: Nissan 300ZX forum - It should fit fine.
Subject It should fit fine.
Posted by TriniTT on August 11, 2008 at 3:30 PM
  This message has been viewed 112 times.
In Reply To Anyone change the 91 tweed interior to 92 suede? posted by DavezTT on August 10, 2008 at 04:27 PM
Message Any interior from 90-93 and 94-96 bolts up directly. Basically, the airbags are what change model for model, and even then only around the glove box area.
Did you use the entire new suede glove box, or did you swap the panels and use the original box? If you did the former, you may want to just swap the panels to see if it fits with your original box. If you used a different box, there may be a latch malfunction keeping it from being able to latch, or something else getting in the way. Give it a try and see how it does.
This is my '91 slicktop with '96 interior:
It does take some modification to go from '90-93 to '94+, but it's quite possible. You shouldn't have the same issues, however, since yours is from a '92.
Cheers,
JBrobst
