TwinTurbo.NET: Nissan 300ZX forum - Re: A Note on pin 58 in certain EFI Harnesses
Subject Re: A Note on pin 58 in certain EFI Harnesses
Posted by RomChip200 on May 28, 2008 at 6:10 AM
  This message has been viewed 1548 times.
In Reply To A Note on pin 58 in certain EFI Harnesses posted by mjm0771 on May 23, 2008 at 07:46 AM
Message I confirm this statement.
This is valid for the EFI harness B4011-31P61 for example, which is an alternative part # for EFI harness 1990-91.
Nissan did that to save costs. The harness runs only one wire (W/B color) from pin 58 to F23/E10 plug and injectors are connected to it in the middle of it as described in the post above.
I didn't want to dismantle the harness in the middle.
Here's the method for this new type of harness:
_F23/E10 plug side: remove the W/B pin from the female plug, this wire becomes the switched injector wire. This step is very important because it isolates the switched 12V from the unswitched 12V (originally W/B color).
_ECU bundle side: open the black bundle of wires and identify the wires of pin 45 (B/R) and pin 58 (W/B). Expose the splicings by removing the adhesive wrap. Cut the W/B wire (58) where the splicing is located. Find an unswitched constant 12V source and weld it to the wire which goes the pin 58 in ECU. Weld the remaining W/B thick wire to the splicing of B/R wire (45). Isolate the exposed wires with thermo sleeves.
Job is done, you have a 12V switched to power the injectors.
