TwinTurbo.NET: Nissan 300ZX forum - Using techtom for injector speed & MAF voltage
nismo_boost31
on May 07, 2008 at 10:42 PM
Usually a Check Engine light
posted by Noncon
on May 07, 2008 at 07:03 PM
I am using a wideband for the A/F, at 6k and 10 psi it was running around 15.2 or so. The 02 sensors are cycling couple times per second and are fairly new. Besides i believe the ECU does not use the o2 sensors after 3k
Symptoms of an inoperative ECU chip???
nismo_boost31
22:06:07 05/06/08
I'd call JWT and ask for their opinion. When this started
ThunderZ
06:12:49 05/07/08
Spoked to a JWT Tech
nismo_boost31
13:31:46 05/07/08
Wow...I thought you'd get some help from those guys.
ThunderZ
21:38:29 05/07/08
Replaced all fuel related parts, bypassed AFC, even
nismo_boost31
22:45:42 05/07/08
You have a spare chip if you did the JWT deal. Swap in
ThunderZ
09:13:52 05/10/08
Have you checked fuel pressure? (n/m)
Fast300
12:28:20 05/07/08
Fuel pressure is dead on & fuel system is clean (n/m)
nismo_boost31
13:19:30 05/07/08
Noncon
19:03:31 05/07/08
Using techtom for injector speed & MAF voltage -
nismo_boost31
22:42:38 05/07/08
Re: Using techtom for injector speed & MAF voltage
Noncon
22:10:09 05/08/08
Maybe the JWT chip is not doubling the MAF signal
nismo_boost31
22:51:36 05/07/08
EPROMS do not just go bad unless you touch them with static
Devi13
03:36:15 05/09/08
I have checked everything
nismo_boost31
09:10:56 05/09/08
