TwinTurbo.NET: Nissan 300ZX forum - Help with hydrolic clutch..
Subject Help with hydrolic clutch..
Posted by Russ ZTT (Jax, Fl) on April 30, 2008 at 2:42 PM
  This message has been viewed 155 times.
Message Got the car back on the road recently and the next day I couldn't get it in gear. So I replaced the slave cylinder and the master cylinder (brand new). I don't have anyone to help with pumping the clutch peddle but I have a vacuum pump that I have been using to bleed the air out of the line. I bled the top and on the slave cylinder and appears fine. Car STILL wont go in gear. There are no leaks under the car from the line. Any ideas what could be wrong? The pressure plate along with the fingers are fine.
RussMan
