TwinTurbo.NET: Nissan 300ZX forum - The TT w/ the bad CAS ran perfectly, even at idle,
ThunderZ
on April 27, 2008 at 8:16 AM
Yeah I had a cas problem before but the thing
posted by Antonio(AZ->NYC)
on April 26, 2008 at 09:51 PM
until it would hit higher RPMs and only at WOT.
I still suggest a known good CAS.
car breaks up in every gear at 5-5500rpm
Antonio(AZ->NYC)
19:56:23 04/26/08
You might be on the right track- stick in some
ThunderZ
20:40:33 04/26/08
Antonio(AZ->NYC)
21:51:55 04/26/08
The TT w/ the bad CAS ran perfectly, even at idle, -
ThunderZ
08:16:16 04/27/08
I have a feeling its the CAS too, I am going to swap it out
Antonio(AZ->NYC)
11:54:30 04/27/08
Make sure you're getting enough fuel.
yobobrox
22:07:50 04/26/08
check and see what spark plugs he has.
nissanguyz32
22:24:14 04/26/08
Good point. Using copper plugs on a car like Antonio's
yobobrox
22:30:00 04/26/08
Just swapped out the cas with one
Antonio(AZ->NYC)
19:07:44 04/27/08
Dead spot inside TPS in WOT? (n/m)
Noncon
18:05:37 04/28/08
