TwinTurbo.NET: Nissan 300ZX forum - Since it's running OK, I wouldn't think it was a leaking
Subject Since it's running OK, I wouldn't think it was a leaking
Posted by ThunderZ on April 25, 2008 at 9:50 AM
  This message has been viewed 119 times.
In Reply To Re: With no wideband installed, how do you know you're running posted by towlett on April 24, 2008 at 07:14 PM
Message lower O-Ring then. A hard start can be a bad Fuel Dampner- pull the vac line and see if there's gas in there.
I've heard the same thing about fuel in oil, washing down the cylinders, etc., but I also read that the gas burns off if you drive longer distances.
The ECUs are usually tuned rich to protect your car- way too rich in many TTs I looked at. I usually have to pull fuel, not add it. They also run much better after doing this. So yeah, I'd get an AFC and a Wideband if I were in your shoes.
