rear studs??? posted by ricky6991 on April 23, 2008 at 07:22 PM
There is one spot behind the hub that allows access to the back of the hub. Rotate the hub so the stud you are working on is over that spot. I recommend spraying the stud with penetrant to loosen things a bit. If you're going to dispose of the old studs, just take a decent size sledge hammer and whack the stud out. If you're saving the old stud, put a nut on the stud to protect the thread when you hit it with the sledge.
Petz #2
"What's the point of having the car if you don't drive it?" - Mrs. Guapo 08/20/05
Jeeeesus Christ - my Dad (after a ride in my Z) 12/26/04
People have the right to freedom of expression. However, people also have the right to point and laugh- aliaZ 04/06/06
