TwinTurbo.NET: Nissan 300ZX forum - code thirty four is for the knock sensor only. It has
red TT (STL)
on April 23, 2008 at 6:15 PM
Re: Re: throttle body cleaned now car wont start
posted by crabara
on April 23, 2008 at 03:51 PM
nothing to do with the oxygen sensors. Your knock sensor is bad. You can either replace it, relocate it, or put a 1k ohm (iirc) resistor in the connector to make the code go away. I would replace or relocate it.
crabara
09:26:34 04/23/08
Re: throttle body cleaned now car wont start (n/m)
crabara
09:32:47 04/23/08
crabara
09:35:43 04/23/08
oh man (n/m)
spicyZ
09:54:23 04/23/08
YES, you need to worry about the straw
spicyZ
09:55:28 04/23/08
Re: YES, you need to worry about the straw (n/m)
crabara
11:03:07 04/23/08
Re: Re: YES, you need to worry about the straw
crabara
11:06:33 04/23/08
red TT (STL)
12:30:37 04/23/08
crabara
15:51:27 04/23/08
You should have taken off
RedTTZ91(OK)
16:14:53 04/23/08
code thirty four is for the knock sensor only. It has -
red TT (STL)
18:15:42 04/23/08
Re: code thirty four is for the knock sensor only. It has
crabara
19:24:01 04/23/08
*1M Ohm (n/m)
spicyZ
07:48:08 04/24/08
correct! :) (n/m)
ZEngineer
08:51:33 04/25/08
