TwinTurbo.NET: Nissan 300ZX forum - Mechanical usually refers to a gauge that is plumbed direct.
Subject Mechanical usually refers to a gauge that is plumbed direct.
Posted by kkrofft (OH) on April 23, 2008 at 2:45 PM
  This message has been viewed 171 times.
In Reply To Re: What kind of gauge is it? posted by swickbt on April 23, 2008 at 11:19 AM
Message If it is electronic (with a sensor which you mentioned) then it is OK. But do NOT put a mechanical fuel pressure gauge inside the cabin!
Always think of what is the worst that could happen. You try to save a few bucks because the mechanical gauge is less expensive. But IF it leaks, and IF it catches fire, you will lose the Z, become horribly disfigured or even die all to save less than $80.
But to answer your new question, remove the fuel cap, disconnect the fuel pump relay and start the car. When it dies, the pressure will be gone. Re-pressurizing will occur
automatically when you turn the key on after reconnecting the fuel lines. Oh and put the cap back on.
KK
