I need opinions ASAP...If you turn the crank with a pull bar, and everything seems lined up (timing belt marks, valves opening/closing at the correct time) then is it possible that when you start the motor there could be valve-->piston contact even if there was none when just turining the crank by hand??? Thank you guys, and once again sorry but I'm just looking for a quick answer.
Very sorry everyone, this should probably be in tech, but - WVZ13:40:07 04/23/08
