I had the same problems...cleaned and cleaned the PTU and CAS with rubbing alcohol and it would fix it for a while and it would come back. Went out and finally found Permatex Dielelectric grease. Fixed the problem. I squeezed some into each female part of the PTU and CAS and well as into each injector connection. Ever since (months ago) I haven't had the problem again.
