TwinTurbo.NET: Nissan 300ZX forum - I always install a bypass switch across the contacts
Subject I always install a bypass switch across the contacts
Posted by jzack on April 22, 2008 at 11:56 AM
  This message has been viewed 279 times.
In Reply To nice -- this system looks like it's a active 100% posted by The Devils Z on April 22, 2008 at 11:22 AM
Message of the cut-off relay (ie., relay that cuts the EFI or Fuel Pump). Thanks - forgot to mention that. Depending on where it's located (not real hard to get to) - I've even epoxied the switch right to the relay case. Or switch can be hidden somewhere else or done with a hidden key switch in glove box, etc.
Bypass switch is also important if vehicle goes in for some kind of mtce and you don't want them to know where the hidden pushbutton is located.
Yes, this design is self-arming.
