TwinTurbo.NET: Nissan 300ZX forum - that will screw things up...
Subject that will screw things up...
Posted by kickerzx on April 22, 2008 at 9:35 AM
  This message has been viewed 126 times.
In Reply To MAF mismatch posted by towlett on April 21, 2008 at 07:18 PM
Message a maf will give a volt reading to the ecu depending of how much air passes through it. it runs from 0-5 volts. what for example 2 volts of air really means for the ecu is programmed in it. now if you use another maf with say a smaller diameter that "2 volts of air" suddenly aint the same mass of air as it was with the other one. your car will run either rich or lean dependant on what you put in there...
