TwinTurbo.NET: Nissan 300ZX forum - Hey Devil, had the same weird problem too...
Subject Hey Devil, had the same weird problem too...
Posted by escturbo on April 22, 2008 at 6:45 AM
  This message has been viewed 233 times.
In Reply To possible solution ...the TPS in closed mode --which means posted by The Devils Z on April 21, 2008 at 02:17 PM
Message My idle would randomly jump to an 1800 rpm idle, stay for a while, and then return to normal again. As you have done, I checked everything and nothing helped.
Ultimately I traced it to the gray TPS connector that connects to the main harness. I found that if I would wiggle that connection, the high idle would drop back down. But, there was nothing wrong with my TPS according to the voltmeter so I wrapped the connection(b/t the gray TPS plug & harness) with aluminum foil and it has fixed the problem ever since. It does look trashy, with the AL foil and all, but it has worked; so I concluded that heat was causing the connection to act erratically and the AL foil wrap provided enough heat shielding to keep it cool enough to operate properly.
*Note that I did initially clean and grease the crap out of the connection and that did not help at all.
I have spent countless hours on this one problem, so feel free to e-mail me and we can duscuss this in more depth.
