TwinTurbo.NET: Nissan 300ZX forum - Try this place - not sure how expensive these are?
Subject Try this place - not sure how expensive these are?
Posted by jzack on April 21, 2008 at 7:44 PM
  This message has been viewed 250 times.
In Reply To Hmmmm.. interesting... you could be right here. posted by spicyZ on April 21, 2008 at 02:59 PM
Message CLICK HERE
For automotive use - these should be rated for a higher heat temperature range (car cabins get pretty hot).
I done versions of what you want to do in other cars -- be damned sure that if this involves a fuel system cutout circuit that the wiring is 100 percent solid. You don't want the fuel pump failing in the middle of high speed passing or similiar...
