TwinTurbo.NET: Nissan 300ZX forum - I agree with Audio. I did my Timing belt and car worked
Subject I agree with Audio. I did my Timing belt and car worked
Posted by 5280Z_nightstalker on April 21, 2008 at 5:01 PM
  This message has been viewed 143 times.
In Reply To I followed the timing belt change from the FAQ in here. posted by WVZ on April 21, 2008 at 03:46 PM
Message before but then some how my injectors had so much corrosion on them and then the car wouldnt start. Make sure you have NO green build up on any connection plug. That goes for the Injectors, Coil packs, Cas, PTU, MAF. If there is any green on them then scrub it off with dental pic's or whatever you can use to get in there WITHOUT bending the connections. If you want to test your electrical system there is some writeups in the FAQ's that tell you what Injectors should OHM at and so forth. I would start with checking these as its a fairly common thing to happen to these cars.
Also I would suggest replacing the plugs as I do that with any vehicle I buy just to be safe. If you decide to replace them get NGK's, as again our cars are picky and dont like Bosch.
I hope thats good enough information for you and good luck with figuring it out.
_Travis
