TwinTurbo.NET: Nissan 300ZX forum - Perhaps a Timer Relay was used.
ked8923
on April 21, 2008 at 2:38 PM
Looking for ideas on ignition/kill switch
posted by spicyZ
on April 21, 2008 at 08:31 AM
Look up timer relay on
http://www.mcmaster.com/
spicyZ
08:31:15 04/21/08
so you DID consider pulling my dash for a moment there! :) (n/m)
ZEngineer
08:54:38 04/21/08
Yes.
spicyZ
08:56:59 04/21/08
fuel pump relay (n/m)
The Devils Z
09:58:56 04/21/08
READ the post, then respond, thanks. (n/m)
spicyZ
10:35:22 04/21/08
Magnetic Switch...
nosduj
10:45:48 04/21/08
that works, but it doesn't answer the question. Allow me to
ZEngineer
10:55:04 04/21/08
How about a magnetic switch that toggles the starter relay
en5
11:17:20 04/21/08
Similar idea, but a PITA if I understand it correctly
spicyZ
11:42:37 04/21/08
I imagined that it was like a magnetic wand that when
en5
15:58:52 04/21/08
Actually, I think nosduj has the right idea
spicyZ
11:39:09 04/21/08
Re: Actually, I think nosduj has the right idea
nosduj
11:57:08 04/21/08
What reverts the switch back to the "open" state? (n/m)
spicyZ
12:10:24 04/21/08
As far as I know, it's held open by a small spring
en5
16:03:42 04/21/08
I did read your original post
The Devils Z
12:37:11 04/21/08
A contact/pressure switch is only on for as long...
spicyZ
13:04:52 04/21/08
I could be wrong --but you may be able to wire it in
The Devils Z
13:37:59 04/21/08
We have a large range of knowledge here
spicyZ
14:03:22 04/21/08
Perhaps a Timer Relay was used. -
ked8923
14:38:31 04/21/08
I believe it would be the Off-Delay relay
ked8923
14:51:22 04/21/08
Hmmmm.. interesting... you could be right here.
spicyZ
14:59:25 04/21/08
np ;) (n/m)
ked8923
15:07:50 04/21/08
and...
ked8923
18:28:21 04/21/08
Try this place - not sure how expensive these are?
jzack
19:44:59 04/21/08
Since you've actually implemented something like this
spicyZ
20:12:22 04/21/08
Here is my solution, complete with part numbers
nosduj
22:49:28 04/21/08
WOW! This is exactly the type of info I'm looking for
spicyZ
07:45:35 04/22/08
good information !!!! nice use of radio shack p/n
The Devils Z
11:16:33 04/22/08
I see no reason why I can't substitute the magnetic
spicyZ
11:36:15 04/22/08
Yep or go really fancy and use some kind of biometric
jzack
18:13:25 04/22/08
bypass
nosduj
20:57:36 04/22/08
Nice write-up. (n/m)
TT XTZ
14:20:03 04/22/08
Well one I installed on an SUV used an aftermarket
jzack
23:00:13 04/21/08
This is also excellent information.
spicyZ
07:47:35 04/22/08
nice -- this system looks like it's a active 100%
The Devils Z
11:22:10 04/22/08
I always install a bypass switch across the contacts
jzack
11:56:57 04/22/08
I have a switch under my seat that kills starter
Mike87T
08:31:57 04/22/08
I want something more sophisticated than a toggle switch
spicyZ
08:48:57 04/22/08
so maybe just a simple push button switch?
Zluster
15:34:57 04/23/08
