TwinTurbo.NET: Nissan 300ZX forum - Check for boost leaks (actual test, not just visual)
Subject Check for boost leaks (actual test, not just visual)
Posted by JaYbOmBz on April 21, 2008 at 9:59 AM
  This message has been viewed 98 times.
In Reply To ?High idle and safety boost? (HELP) posted by Jayme on April 20, 2008 at 05:04 PM
Message I've had high idle problems in the past that were caused by boost leaks I couldn't find by just looking. After I hooked it up to a tester I found several large leaks.
It doesn't necessarily explain the safety boost but you can never go wrong testing for leaks. Just make sure to read up on the proper procedure.
