Me and my brother swapped his over from wheel to column. His is a 90 and my wreck was a 93. He kept his factory wheel, just didn't like the cruise buttons on the cover. We had to take the complete stacks will all the wire you can.We also used the shroud. You can modifiy your shroud if you wanted. I believe the colors for the cruise control wires were the same. I will double check. The only thing I believe is he still has to use the on/off button on the whell then use the stalk to set/resume/coast. I don't k now if this helps you or not. Frank
