TwinTurbo.NET: Nissan 300ZX forum - Re: Here's what i found, just some little stuff that will help
Subject Re: Here's what i found, just some little stuff that will help
Posted by towlett on April 20, 2008 at 7:04 AM
  This message has been viewed 101 times.
In Reply To Here's what i found, just some little stuff that will help posted by Sleeper_TTZ(SeKy) on April 20, 2008 at 12:07 AM
Message Thanks, I cleaned and reassembled the two connections that go right into the PTU box, one didn't have a clip on it and the connections were corroded green, the other one looked okay but I cleaned them both anyway.
I used some fine grit sand paper, a tiny screw driver, and some contact cleaner from radio shack, then I made a clip for the one that was missing, put them back together, used some dielectric grease, and wrapped everything up tight with electrical tape. So far so good, I took a 15 minute test drive with no problem. Will do some more driving today.
I didn't go to the sub harnesses though. I guess I could follow the lines further and check those out too. Do you know what those sub harnesses power?
From 300ZX TT Road...
