TwinTurbo.NET: Nissan 300ZX forum - cylinder 1?, furthest forward, passenger side
Subject cylinder 1?, furthest forward, passenger side
Posted by towlett on April 19, 2008 at 2:02 PM
  This message has been viewed 126 times.
Message cylinder working intermittently. I tested the injector and it reads correct ohms, around 12-13, getting power at connector for injector too. What can I test now? Any idea what the problem-solution might be? This is tough because it comes and goes, when I tested with the meter everything was working okay. Connections all look clean, coil packs have replacement clips so they are secure.
I know what cylider is acting up because I pulled the coil packs when it WAS running rough and there was no difference on that cylider when pulled, but the problem went away again before I could do the ohm and voltage tests I refered to above.
If it's not currently acting up does it make sense to go through chekcing the continuity between the ECU and injector?
From 300ZX TT Road...
