| Message |
Hello, I recently fired up my Z after a long rebuild process; everything is running fine except for the fact that the ECU is throwing a code 42. This seemed strange since I had replace the fuel temp sensor during my first rebuild and I had just replaced the FPR and damper. Following the manual, I checked the fuel temp sensor with my voltometer and it checked out. Next I checked the voltage from pin 36 and it checked out (Read .49 I think, which was slightly under the .5 max). Now Im at a loss as to what it can be. I had removed the PRVR system and rerouted the vacuum lines prior to start up; could this play into the problem. Any suggestions are welcome. Thanks.
