TwinTurbo.NET: Nissan 300ZX forum - engine problem
Subject engine problem
Posted by Jaskozx on April 17, 2008 at 8:46 PM
  This message has been viewed 173 times.
Message Hey i have a couple of questions for you guys out there. I'm only 17 and i need help with my car, i did the self diagnostic ecu test and i got a code 34 which is detonation sensor circuit, i think the reason for that is my fuel injectors are bad. I took out the wires out of the injectors and two of them were cracked with this disgusting green mold or something like that,I still have the stock 370cc injectors in the car, and i wanted to know if i buy the nismo 55cc injectors with a good performance rail, also an EFI harness would that solve my problem of my car running on 4 cylinders and engine vibrations? also can you change the harness with the engine in, while your changing all of your injectors or should i take it out? THANKS
