TwinTurbo.NET: Nissan 300ZX forum - Swapped brake rotors, now I can't move
Subject Swapped brake rotors, now I can't move
Posted by roninknight7 on April 14, 2008 at 12:40 AM
  This message has been viewed 197 times.
Message I have a 1990 2+2 with cross-drilled/slotted rotors up front, and a 1990 TT with regular rotors up front. I did a rotor swap, only the front rotors. Now the 2+2 have regular rotors and the TT have the cross-drilled/slotted rotors. Both pairs of rotors are 30mm.
I haven't put the calipers back on the TT yet (planning to paint the calipers), but I did put back the calipers for the 2+2. I then bled the brakes for the 2+2, both front driver and front passenger. When I turned on the ignition of the 2+2, I can't even move, the brakes seems like its engaged. But the brake pedal feels normal. Any ideas what the problem could be? Should I bleed again? Thanks!
