TwinTurbo.NET: Nissan 300ZX forum - Clutch noise problem
Subject Clutch noise problem
Posted by Attila on April 13, 2008 at 2:41 PM
  This message has been viewed 182 times.
Message Hi,I changed my flywheel few weeks ago. I replaced genuine Nissan flywheel to a new genuine one.
Since did this change,I experience the following:
1. I hear a continuous high frequency clicking sound from the middle lower portion of the car, when the engine is at idle.
2. If I remove my leg fast from the clutch pedal, I hear creaking noise from the clutch area. It happen in any gear, It is louder if the engine (clutch) is hot. I also had this noise before I did the flywheel change, but very rarely and it was not as loud as now.
3. This morning, when I turned the ignition key, I heard a big noise and I released the key. I tried again and the engine started without any problem.
Maybe this 3 problem is independent. First is the exhaust, second is the pressure plate, the last one is the magnetic switch in the starter.
I do not know, maybe all of the caused by the same fault.
Please help. Thanks, A.
  • Clutch noise problem - Attila 14:41:37 04/13/08
