TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Car wont start, and battery is getting drain.
Subject Re: Re: Car wont start, and battery is getting drain.
Posted by Rob260 on April 11, 2008 at 2:59 AM
  This message has been viewed 139 times.
In Reply To Re: Car wont start, and battery is getting drain. posted by 91Z_man on April 11, 2008 at 12:46 AM
Message :Well know that i think about it, i have had my Seat belt light on for about the same time that the problem started but i dont know how that may affect the batt been drain though??
So are you saying the seatbelt light is staing on? If yes then that is your culperit as even a small drain over enough time will flatten the battery. You can do a current draw test by hooking up a multi meter (set to amps) in line with the negative terminal and the negative battery post. You should see a low reading like .4 amps, if higher then you have confirmed yes you have a current draw. Start pulling acc fuses until you see the drain drop....
