TwinTurbo.NET: Nissan 300ZX forum - 3 things to try:
Subject 3 things to try:
Posted by jcieslik on April 10, 2008 at 9:58 PM
  This message has been viewed 142 times.
In Reply To What am I forgetting? Red Z problems. posted by MistressZ on April 10, 2008 at 09:24 PM
Message 1. Check for boost leaks. A vacuum leak will cause a car to not start if it is big enough. Also check to make sure the mass air flow sensor is hooked up. Mine would not start once because of that.
2. Are you positive all the injectors are good? Ohm them if you are not sure.
3. After that I would go after the six Ps.
Jeff Cieslik
