hmmm thats odd. those are really the only things that can leak on the rear. is the housing itself cracked? even slightly? sorry i missed in your first post that you said you replaced the end seal on the oil pan. if the crank isn't wore or damgaed that should be the problem. is the spring staying in the seal when you install it?
