TwinTurbo.NET: Nissan 300ZX forum - still having electrical problem, no climate control....
Subject still having electrical problem, no climate control....
Posted by OriginalGate21 on April 10, 2008 at 2:02 PM
  This message has been viewed 209 times.
Message im still having electrical problems in my 93z.
No Climate Control, doesnt turn on
Power windows dont work at all
Power Steering is hard
ABS Light Stays On
No Direction Signals
No Door chime
All other accessories work in the vehicle like rear defroster, wipers, hazards, radio.
Ive replaced a diode part 24335 behind the drivers seat inside the wiring harness panel like iwas told, didnt change nothing.
Checked all fuses. GOOD. Checked all relays. GOOD. Swapped Relays to be safe. Still good. Even Accessory relays inside the kick panel under the fuse block. GOOD
Checked Timing Control Unit, 12 volts through the pins according to the manual.
What else more can i check? What Controls these things that arent working? Where else to look?
Im giving up and do not want to take it to the dealer for diagnostics as they will rape me
Thanks
