TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Why not just remove the entire ignition switch assem
devious_one
on April 09, 2008 at 5:32 PM
Re: Why not just remove the entire ignition switch assembly
posted by red beast
on April 09, 2008 at 12:17 AM
I believe you can dremel a slot in them for a flathead screwdriver.
Need Help
red beast
16:16:29 04/08/08
Call a locksmith (n/m)
Audioquest
16:25:46 04/08/08
Re: Call a locksmith
red beast
16:32:49 04/08/08
If that part is broken off way inside the lock, I have no
Audioquest
16:53:45 04/08/08
Re: If that part is broken off way inside the lock, I have no
red beast
17:28:48 04/08/08
Is that a guess or did you phone around?That seems pretty hi (n/m)
Audioquest
17:37:14 04/08/08
Re: Is that a guess or did you phone around?That seems pretty hi
red beast
00:13:18 04/09/08
For that money, they'd have to spend almost 3 hours
Audioquest
08:06:32 04/09/08
You already tried and failed. (n/m)
spicyZ
21:35:50 04/08/08
Re: You already tried and failed.
red beast
00:13:53 04/09/08
ignition will or won't turn? (n/m)
robo (sebring1970)
16:47:33 04/08/08
Re: ignition will or won't turn?
red beast
17:29:54 04/08/08
jzack
18:29:53 04/08/08
red beast
00:17:54 04/09/08
Re: Re: Why not just remove the entire ignition switch assem -
devious_one
17:32:50 04/09/08
Others have posted using that method too... (n/m)
jzack
22:59:15 04/09/08
Re: Need Help
inferno
05:25:45 04/09/08
Re: Re: Need Help
red beast
16:23:42 04/09/08
Re: Re: Re: Need Help
inferno
05:23:29 04/10/08
you cant unlock your wheel, but you can turn it
aidemsined (to)
01:36:31 04/10/08
Instead of wire get some thin tweezers...
Sportzcoop
01:45:37 04/10/08
