TwinTurbo.NET: Nissan 300ZX forum - TPS, injectors, PTU and CAS do not make a popping sound
Subject TPS, injectors, PTU and CAS do not make a popping sound
Posted by doug8867 on April 08, 2008 at 3:31 PM
  This message has been viewed 203 times.
In Reply To Re: RPMS flatline, car dies, wont get back up posted by ouikikazz on April 08, 2008 at 10:20 AM
Message when they fail. However, a hose popping off under pressure does. First rule
of diagnosis: Listen to the customer's description of symptoms. Second rule:
Don't overlook the obvious. :-)
ps. I've had an air leak from a misaligned plenum gasket that prevented the
car from starting before, so if one of the intercooler pipes/hoses or recirc.
hoses popped off they would create a large enough gap to prevent starting.
Not saying an air leak is definitely the problem, but would be the most obvious
one to check first based on his description of events.
