TwinTurbo.NET: Nissan 300ZX forum - Just to add something else into the mix, if it's running
Subject Just to add something else into the mix, if it's running
Posted by Audioquest on April 08, 2008 at 12:44 PM
  This message has been viewed 133 times.
In Reply To Re: Hes right and the car wont run because of that. posted by Schoch(NC) on April 08, 2008 at 12:36 PM
Message rough, have you checked obvious things like the Coolant Temp Sensor, MAF, CAS PTU connections seeing as you were working in that area? Could just be a poor connection.
Also as NytWolf says you should throw a timing light on there to see if it jumps around a lot. If your CAS is set to about center in the adjustment slot/range and it shows about 15 BTDC it's probably not the belt.
