TwinTurbo.NET: Nissan 300ZX forum - Speedy Sleeve
Subject Speedy Sleeve
Posted by Audioquest on April 08, 2008 at 11:22 AM
  This message has been viewed 491 times.
Message Is there a speedy sleeve available for the rear crank seal surface?
I have change the rear seal 3 times in the last 2 years and it still leaks minimally. The surface seems free of wear, yet it continues to weep a bit.
I removed the rear seal aluminum casting and installed a new gasket as well as the oil pan half-moon seal yet it won't stop.
Drive for a while, park, leaves a solver dollar size mark then stops.
Is there something I am overlooking behind the flywheel that could leak?
I don't mind pulling the tranny again to fix, it but if it does a fourth time, I might have to be restrained!
