TwinTurbo.NET: Nissan 300ZX forum - Definitely. The pistons with be at TDC and everything
Audioquest
on April 08, 2008 at 10:55 AM
Re: Then it will never be in time
posted by Schoch(NC)
on April 08, 2008 at 10:31 AM
else won't be in time as the crank is no longer in sync with the cams
timing belt change issues
Schoch(NC)
09:55:30 04/08/08
Then it will never be in time (n/m)
Audioquest
10:23:15 04/08/08
Schoch(NC)
10:31:16 04/08/08
Definitely. The pistons with be at TDC and everything -
Audioquest
10:55:56 04/08/08
If you are sure it's off, take it apart again. All you have
Audioquest
10:58:28 04/08/08
Hes right and the car wont run because of that.
5280Z_nightstalker
11:10:43 04/08/08
Re: Hes right and the car wont run because of that.
Schoch(NC)
12:36:12 04/08/08
Just to add something else into the mix, if it's running
Audioquest
12:44:50 04/08/08
If you were off a tooth or two ...
NytWolf
11:43:49 04/08/08
Re: If you were off a tooth or two ...
Schoch(NC)
12:33:24 04/08/08
