TwinTurbo.NET: Nissan 300ZX forum - thats what I use...
thats what I use...
spyhunterTT + 93Vert(nj)
on April 07, 2008 at 6:23 PM
Along with those suggestions these should also do the trick
posted by Barry (NJ)
on April 04, 2008 at 06:31 PM
one thing to note: i normally have to break the bolts loose with a normal wrench as those are just slightly too thick for the area and don't 100% clear the egr tube. But once the bolt has been broken free, the ratch wrench does wonders
Alex
plenum removal question...
Madhatter10-6
18:00:50 04/04/08
The first time I did it many years ago, I used a cut-off
whitepearlz
18:04:51 04/04/08
that would work fine
aliaZ
18:05:22 04/04/08
I just used a universal joint and a 10mm socket. (n/m)
rojoloco (San Diego)
18:07:25 04/04/08
Are you going to keep that on there. I just cut the
Sleeper_TTZ(SeKy)
18:14:31 04/04/08
im going to delete that system
Madhatter10-6
18:16:10 04/04/08
empty holes in the bottom of the plenum that is (n/m)
Madhatter10-6
18:16:56 04/04/08
You can use the flanges from the stock tubes
Kong ZTT GT28RS MD
18:18:42 04/04/08
300 degree makes a kit for them, But I'm taping them
Sleeper_TTZ(SeKy)
18:23:03 04/04/08
The kit...
Sleeper_TTZ(SeKy)
18:24:29 04/04/08
Stubby 10mm ratchet wrench..
Kong ZTT GT28RS MD
18:17:16 04/04/08
tt.net ROCKS!
Madhatter10-6
18:27:41 04/04/08
Barry (NJ)
18:31:14 04/04/08
thats what I use... -
18:23:33 04/07/08
10mm Gear Wrench flex head ratcheting wrench FTW! (n/m)
doug8867
18:56:57 04/04/08
