| are showing vacuum and the needles are not moving. over the winter i pulled the plenum, removed the egr, c.c., aiv's, coolant bypass, and did a 5 speed swap. Car started with no problems and runs really smooth. When i took it around the block it seems to building boost, let of the gas blow off valves did their thing and can hear the turbos spool.
I have an autometer boost gauge and the really accurate factory one. Both of them are just showing vacuum, neither of the needles are moving. Any ideas of what i should start looking for?
"When you are fitted in a racing car and you race to win, second or third place is not enough." ~ Ayrton Senna "If everything seems under control, you're just not going fast enough." ~ Mario Andretti |
