TwinTurbo.NET: Nissan 300ZX forum - Cant get the greddy profec b to work properly! HELP!!
Subject Cant get the greddy profec b to work properly! HELP!!
Posted by BeachTTRacer on April 06, 2008 at 3:47 PM
  This message has been viewed 197 times.
Message Here is the deal. I have hooked up the greddy profec b. I thought it was working properly.. but I cant adjust it. I have read up on it.. but I read something in the manual about a something that may need to be bypassed. I have taken a few pictures... to see if I am correct.. so.. here goes. BTW... just for gerneral knowledge.. at first I ran the hard plastic line and was told that didnt move enough boost for the greddy to read right... so I switched to a 4mm black vacuum line. It keeps spiking at 15-19 psi. So I removed the profec and put in a straight line to run stock boost.. it is hitting at about 10 psi.. is that normal? Also... in the pictures below do I need to remove that solenoid just above the turbo's? Do I just plug them off? the second picture is of the location of the valve and how I bypassed it.. 2 of the blue lines are just hanging there...
2' Aluminum Wing -$200
Cold air intake -$49
Loud annoying muffler -$149
Your Girl-friend checking me out while I smoke your mad tight Pep-Boys Civic - Priceless
Honda's are upgraded with pocket change.
For everything else we use PERFORMANCE PARTS!
88ss - http://www.cardomain.com/ride/2239581
90tt - http://www.cardomain.com/ride/2261993
