| Subject |
If you've already checked fuses and relays, try the |
| Posted by |
GPA on April 05, 2008 at 2:13 PM |
This message has been viewed 190 times. |
| In Reply To |
Power windows and power locks wont work posted by mogaffar on April 05, 2008 at 09:29 AM |
| Message |
combination switch on the driver's door panel. If it is the same as my '92, then it's got the power door lock button, driver's window switch, and pass window switch (the 3 items connected to your problem). I'm not sure, but power may go through this switch before it goes to the switch on the pass door, which might explain why you also get nothing from the pass side window switch. Check to see that you have 12v going to the switch. If you don't, then trace voltage backwards (toward the battery) from there. If you do, then operate the switch and check for 12v coming out of the switch. If you don't have voltage coming out, then the switch is bad. If you have 12v going in and coming out, then trace it forward from there. Hope that makes sense.
| Follow Ups |
Post a Followup |
