TwinTurbo.NET: Nissan 300ZX forum - Re: Low Oil Pressure and shaking while at idle.
Subject Re: Low Oil Pressure and shaking while at idle.
Posted by txq45 on April 03, 2008 at 9:06 AM
  This message has been viewed 267 times.
In Reply To Low Oil Pressure and shaking while at idle. posted by BannonZ on April 02, 2008 at 11:43 PM
Message Common problem low pressure at idle..
Your pressure is OK.. and it sounds like you should be able to go anywhere..the problem is the smoke from the exhaust and oil smell.
No leaks? Looked at bottom of turbos back and front of engine for leaks? If none look inside your air duct tubes.. tubes that come from the air cleaners to the turbo and then from the turbo to the intercoolers. Could be something simple like PCV hoses and valves
