Here's something else .. you've got a car with injectors over 15years old that's using fuel it wasn't designed for ethenol Two things, first you should re-wire your injectors so that they're switched power not power on all the time.. Look up the write up from Jim Wolf to Nissan and the write up from Greg Dupree to Nissan..then because of finances replace know bad injectors
