TwinTurbo.NET: Nissan 300ZX forum - nightstalker...one more question..thanks
Subject nightstalker...one more question..thanks
Posted by MsHyde on April 01, 2008 at 12:20 PM
  This message has been viewed 123 times.
In Reply To If you dont have money for injectors i would do some posted by 5280Z_nightstalker on April 01, 2008 at 01:27 AM
Message :research on DeatschWerks. I personally dont know what to think of these to be honest. I havent tried them nor do i know anyone personally who has. I do know however that some people here have and you may want to look them up and email them to get there scoop or post something here or in the general section.
:You asked in my previous post what you need to install them:
:6 injectors of your choice. (mine=$725)
:Top and bottom injector orings. (~$10)
:Fuel rail orings and cap insulators. (~$28)
:300 degree fuel rails and Specialty Z install kit. ($525)
:If going with new style injectors on old style car you will need new injector connectors. ($45)
:ALL EQUALS A TOTAL OF ~$1330
:Another option that i have heard of to be cheaper is the above mentioned DeatschWerks. I can not say they are good nor bad as i have no dealings with them. Hopefully someone can tune in and try to help you out here. 1 bit of advice i will give you though is do not buy old used injectors. You have to consider your time and effort of tearing into this car to replace these and realize that spending a little more now will save you big headaches later. I hope that helps you out some and if you need any help dont be shy to email me with questions. Ill try to answer what i can as i have just purchased and installed my injectors this month.
:Good luck
:5280Z_nightstalker
I have a question about the parts above:
If will need the 300degree rail and kit and new style injectors ONLY if I go with the new style injectors (regardless of cc). Correct?
If I simply buy old style (370 or 550), I would only need the injectors, o-rings and maybe old style connectors. Correct?
Thanks
