TwinTurbo.NET: Nissan 300ZX forum - 2nd i was having same issue - some would even show no
aidemsined (to)
on March 31, 2008 at 4:54 PM
They're likely very corroded
posted by spicyZ
on March 31, 2008 at 04:24 PM
reading at all until cleaned - bad connection will affect resistance.
Strange case... a bit long...help appreciated
MsHyde
01:46:52 03/31/08
Re: Strange case... a bit long...help appreciated
MsHyde
02:05:27 03/31/08
Re: Re: Strange case... a bit long...help appreciated
WazTTed
07:29:20 03/31/08
Re: Re: Re: Strange case... a bit long...help appreciated
MsHyde
12:48:28 03/31/08
txq45
07:56:32 03/31/08
MsHyde
12:56:04 03/31/08
What proof do you have that the rewire does anything?
spicyZ
16:25:56 03/31/08
4 of 6 are done. Also pull all other connectors and
Audioquest
09:02:41 03/31/08
Re: 4 of 6 are done. Also pull all other connectors and
MsHyde
13:00:19 03/31/08
Re: Re: 4 of 6 are done. Also pull all other connectors and
MsHyde
13:01:11 03/31/08
Your Ohm readings are way to high.
5280Z_nightstalker
14:09:59 03/31/08
Re: Your Ohm readings are way to high.
MsHyde
19:27:54 03/31/08
One of the most vulnerable areas of the Z are those
Audioquest
14:24:34 03/31/08
Are the readings the same after cleaning up the contacts? (n/m)
spicyZ
16:27:03 03/31/08
spicyZ
16:24:45 03/31/08
2nd i was having same issue - some would even show no -
aidemsined (to)
16:54:46 03/31/08
Re: 2nd i was having same issue - some would even show no
MsHyde
19:22:18 03/31/08
Re: Re: 2nd i was having same issue - some would even show n
MsHyde
19:23:25 03/31/08
Re: They're likely very corroded
MsHyde
19:22:43 03/31/08
Re: Re: They're likely very corroded (n/m)
MsHyde
19:23:36 03/31/08
Update
MsHyde
00:40:50 04/01/08
If you dont have money for injectors i would do some
5280Z_nightstalker
01:27:37 04/01/08
Also that is a very strange thing to happen when Ohm testing
5280Z_nightstalker
01:29:45 04/01/08
nightstalker...one more question..thanks
MsHyde
12:20:20 04/01/08
Re: nightstalker...one more question..thanks
spicyZ
14:02:15 04/01/08
Seems pretty clear that the majority are toast
spicyZ
07:45:28 04/01/08
Re: Seems pretty clear that the majority are toast
MsHyde
12:07:08 04/01/08
Edit your profile
spicyZ
13:59:07 04/01/08
Yup. they are done alright. At minimum, if you need the
Audioquest
10:01:47 04/01/08
I have some old 370cc injectors off my 91TT but i think it
5280Z_nightstalker
10:57:37 04/01/08
Re: I have some old 370cc injectors off my 91TT but i think
MsHyde
12:09:30 04/01/08
Re: Yup. they are done alright. At minimum, if you need the
MsHyde
12:09:14 04/01/08
