TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Strange case... a bit long...help appreciated
Subject Re: Re: Strange case... a bit long...help appreciated
Posted by MsHyde on March 31, 2008 at 12:56 PM
  This message has been viewed 104 times.
In Reply To Re: Strange case... a bit long...help appreciated posted by txq45 on March 31, 2008 at 07:56 AM
Message :Yes, you have a injector problem.. You can go to JWT's site and read up on it or look up Greg Dupree's write up. To have you car run correctly you do need to change your injectors, but to keep the NEW injectors from failing you also need to do the Switched Injector re-wire.. info located in the FAQ
Thnaks for you input
ARGH...I now remember using some BK44 cleaner in the engine...I had read some warnings against it, but thought one can in 33K miles would not make a huge difference and I thought no car is that sensitive....I am now paying the price...
i will study the re-wire procedure.
Thanks
