If you are just trying to change the transmission oil you can take it to a regular oil changing place and they can pump the oil out through the fill hole on the side of the tranny. Most of them have a pretty good pump and will get at least 95% of the old oil out. I have to do that with mine because it is stripped. Now if it is the fill plug then you have a problem and I don't know what to tell you. Good Luck!!
