TwinTurbo.NET: Nissan 300ZX forum - *big screwdriver. Read the post, n99b (n/m)
ZEngineer
on January 30, 2008 at 12:48 PM
Screwdriver to remove that? What you been smoking today?
posted by spicyZ
on January 30, 2008 at 12:46 PM
SZR: rounded/stripped transmission plug
RedSER13
12:29:11 01/30/08
Welded socket didn't work?
BradZ (FL)
12:34:59 01/30/08
I'd make a slit right though its face with a dremel
ZEngineer
12:37:33 01/30/08
spicyZ
12:46:54 01/30/08
*big screwdriver. Read the post, n99b (n/m) -
ZEngineer
12:48:31 01/30/08
Attn: ZNongineer
Kenny
12:52:00 01/30/08
Pfft, shows how much experience you have with slits. (n/m)
BradZ (FL)
12:55:00 01/30/08
ok, fine, it was a bad idea, call off the dogs (n/m)
ZEngineer
13:00:25 01/30/08
We're not done with you yet. (n/m)
Kenny
13:12:25 01/30/08
uhmm. George, besides the bad idea of using a big screw
Cap927(Boston)
14:12:02 01/30/08
yes, this is the one. (n/m)
RedSER13
14:34:11 01/30/08
Nice try! (n/m)
Spongerider :)
14:37:07 01/30/08
weld socket, tighten then loosen (n/m)
ZiNnYc
12:40:44 01/30/08
2nd on the tighten first (n/m)
spicyZ
12:46:21 01/30/08
Try PB blaster or Freeze off, should be in any auto store (n/m)
DoodMon(SD)
12:43:22 01/30/08
What happened to the welded socket?
bliZard
13:13:17 01/30/08
the weld just broke and kissed my $10 goodbye. (n/m)
RedSER13
14:35:34 01/30/08
Oh I remember doing this... Not fun.
MixManMash
13:48:01 01/30/08
OOO! A MaGiCaL StOrY! (n/m)
ZiNnYc
13:51:46 01/30/08
Helpful! :-) (n/m)
spicyZ
14:12:38 01/30/08
nice. i can use this. (n/m)
RedSER13
14:36:18 01/30/08
if welding a socket to the plug failed probably because
Cap927(Boston)
14:24:59 01/30/08
thanks. i'll look around for this tool. (n/m)
RedSER13
14:37:43 01/30/08
it's actually not a tool, but square metal stock
Cap927(Boston)
14:49:26 01/30/08
i also tried heating up the plug before loosening.
RedSER13
14:42:16 01/30/08
yeah, the plug needs to be cold and the tranny hot.
BlackholeZ
15:07:53 01/30/08
Buy a suction device and use the vent hole to suck
spicyZ
15:09:43 01/30/08
Have you ever had this out before?
bliZard
15:39:46 01/30/08
yes, i've had it out before and it wasn't rounded.
RedSER13
15:52:32 01/30/08
Use PB blaster.. and heat that shiz up..
Kong ZTT GT28RS MD
15:17:56 01/30/08
I had the same problem this week....
Z1rider
15:32:06 01/30/08
Another ting I've used as a last resort
BlackholeZ
17:15:25 01/30/08
Ive had some good luck with an air hammer.
Knapper411
18:38:37 01/30/08
How about get a big easy-out and cut it off so you
Audioquest
21:30:04 01/30/08
If you are just trying to change the trans oil
goldentt
08:24:39 01/31/08
If you are still having problems, try this way.
dswtflip4u
21:50:20 01/31/08
The weld was not clean. Get someone who knows what they
jcieslik
22:41:38 02/01/08
