TwinTurbo.NET: Nissan 300ZX forum - Matco..."PNP-8"?
Matco..."PNP-8"?
Fly-Surf
on January 16, 2008 at 8:03 AM
9 times out of 10 I use something like this, grab the injec-
posted by Bernie (NoVA)
on January 15, 2008 at 11:19 PM
:tor by the connector & pull straight up.
COOL!
Injector removal secrets?...dremel technique
Fly-Surf
20:23:24 01/15/08
my best tool for that is a pair of long nose vise grips
Guapo
20:39:38 01/15/08
Re: my best tool for that is a pair of long nose vise grips
Fly-Surf
07:52:11 01/16/08
I wrap the jaws mine with some tape to soften.
mossyoak
13:40:51 01/16/08
let it soak overnight in the PB Blaster, try again tomorrow
robo (sebring1970)
22:22:53 01/15/08
Some one here said they drilled
818TTZ(SoCal)
22:56:40 01/15/08
That's usually my "all the plastic has broken off" fall back (n/m)
23:20:09 01/15/08
THANKS 818TTZ and Bernie!
Fly-Surf
07:53:53 01/16/08
Still no luck...any warnings about drilling?
Fly-Surf
19:35:29 01/16/08
If anthing the fuel pressure would help push it out.
23:37:47 01/16/08
Thanks...maybe I should pressurize the system :-) (n/m)
Fly-Surf
09:21:56 01/17/08
might be time to say "uncle" and pull the plenum (n/m)
robo (sebring1970)
01:28:30 01/17/08
I'm almost at that point! But...
Fly-Surf
09:23:40 01/17/08
Okay...now what?
Fly-Surf
19:05:49 01/18/08
Did you hit it somewhere as it came out or was it just
20:04:35 01/18/08
Re: Did you hit it somewhere as it came out or was it just
Fly-Surf
20:16:00 01/18/08
Bottom line...If its flaoting in the fuel rail...
Fly-Surf
20:25:59 01/18/08
Looks like I'm done...car is back to NORMAL!
Fly-Surf
08:46:22 01/20/08
23:19:26 01/15/08
2nd
ZXRider(SoCal)
03:14:12 01/16/08
Matco..."PNP-8"? -
Fly-Surf
08:03:06 01/16/08
There are pleny of similar but cheaper options out there
08:12:42 01/16/08
Re: There are pleny of similar but cheaper options out there
Fly-Surf
08:57:07 01/16/08
Yes - the angle of the plies offsets the angle of the
11:52:44 01/16/08
Harbor Freight is cheap for those
robo (sebring1970)
16:54:34 01/16/08
dont forget 1/8 inch counterclockwise/clockwise
mossyoak
13:35:13 01/16/08
